Eventually it gets to the point where the water in a tadpole container needs to be changed. For the replacement water I use well water, as the tap water contains chlorine. I empty about half of the water from the container and pour it into another container. The pouring into another container is a safety measure in case any tadpoles are accidentally poured out. I let the replacement water and the container sit in the same environment for some time to allow for the temperatures to equalize. Then of course I slowly pour the replacement water in.
Going a bit off-topic, I've noticed that the tadpoles have been doing fine without me blowing bubbles into the water to dissolve some oxygen.
