| /sbin # arp doc_loadbios docfdisk flash_erase flash_eraseall flash_info flash_lock flash_otp_dump flash_otp_info flash_unlock flashcp ftl_check ftl_format getty ifconfig ifdown ifup init insmod klogd logread lsmod modprobe mtd_debug nanddump nandtest nandwrite nftl_format nftldump pivot_root recv_image rfddump rfdformat rmmod route serve_image setconsole slattach start-stop-daemon sulogin sumtool switch_root sysctl syslogd udevadm udevd udhcpc | /bin # addgroup adduser ar6000.ko ar6000_sta.ko ar6k-wps-oob.conf ash at atcsms athtcmd_ram.bin athtestcmd athwlan.bin.z77 athwlan_sta.bin.z77 atproxy atserver bbconfig bmiloader busybox call cat chgrp chmod chown cms cp cpio data.patch.nopa.bin data.patch.pa.bin date delgroup deluser device.bin df dhcpc dhcps diag_switch dmesg dnsmasq dumpkmap echo eeprom.AR6002 egrep factory FALSE fgrep getopt grep gunzip gzip hostapd hostapd_cli hostapd_wps hostname httpd ip iperf iptables iwconfig iwlist iwpriv kill lld2d ln login ls mic mkdir mknod mktemp more mount mv netstat nice nmbd nopa.bin nopaartagent nvram nvram_linux_test pa.bin paartagent pidof ping ps pwd qmiserver reboot rm rmdir run-parts sh siproxd sleep smbd smbpasswd sntp startsntp stty su sync syswatch touch TRUE ui_main umount uname upnp usleep wificonnect wmiconfig xmlreporting xmltest zcat | /usr/bin # arping basename chvt clear cut dc deallocvt dirname env expr find free ftpget ftpput head hexdump hostid id ipcrm ipcs killall less logger md5sum nslookup od passwd printf readlink renice reset seq sort strace strings test tftp time top tr traceroute tty uptime wc wget xargs | /usr/sbin #
brctl chroot figlet inetd rdate setlogcons |
