Finally sending the #Sprite Wand LED cube off. I did a couple of tweaks before hand to increase its versatility a bit. In addition to the internal connections to mount it on the end of a rod or wire, I added pairs of 4 point connection pads on opposing sides. Four on one side are +/- and Data/Clock In and the opposing side are power and Data/Clock Out. This will allow for cube to cube chainability in at least one direction. I started down a rabbit hole of maximum chainability but had to stop, outside the scope of this, I can easily to another run. Focusing instead on the ascetic portions on this I included edge solder tabs to maximize rigidity, I hope this will help keep the cube shape nice and tight.
This weeks board is something weird, with LED's and edge lighting. Stay Tuned.
