Required tools:
- Stencil.
- Solder paste.
Applying the paste.
For this operation, I have designed a PCB fixture with a mount for interchangeable stencils.
Setting the PCB and aligning the stencil after that apply some duct tape.
Now we can mount components.
When placing the components press components a little bit in the solder paste.
Now solder components using a solder station hot air.
And fix if needed some unsoldered components.
