Wifi dot matrix printer adapter
Add wifi printing to a dot matrix printer
Public Chat
  • 1 × esp8266
  • 1 × atmega328 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
korneliuszo wrote 06/22/2020 at 20:11 • point
there is buffer in printer which sends busy signal to atmega. There is buffer in atmega which sends busy signal to esp (esp doesn't have flush on uart so avr needs buffer bigger than esp hw fifo). There is buffer in esp (TCP stack). There is buffer on socket in PC. So as flow control is everywhere data caches in some buffer.
Example usage in linux(bash): echo -n -e "Hello world\r\n" > /dev/tcp/192.168.4.1/9100
Mike Szczys wrote 06/22/2020 at 18:53 • point
Cool, WiFi to parallel bridge. Are there any timing issues to consider? I'm not sure how much data it takes to run the printing protocol but I'd guess you need to cache most of it while you wait for the print head to catch up.
