Background Research 06-21-2020:
- blood warmers are rarely needed during routine transfusions, they are used when rapid transfusion of components is required
- blood storage temperature, 2 to 6degC (whole blood/red cell component)
- blood tranfusion temperature, 30 to 37degC
- suggested rate of transfusion (adult)
+ whole blood 150-200mL/hr
+ PRBC (packed red blood cells) 100-150mL/hr
+ platelets/plasma 150-300mL/hr
- suggested rate of transfusion (pediatric)
+ whole blood/PRBC, 2-5mL/kg/hr (17 mL/min allows transfusion in less than 30 minutes)
+ platelets/plasma, 1-2mL/minute
- duration times for transfusion
+ whole blood/PRBC, less than 4 hrs (start within 30 minutes of removing from refrigerator)
+ platelet concentrate, less than 30 minutes (start immediately)
- warmed blood is most commonly required for:
+ large volume rapid transfers
* adults, more than 50mL/kg/hr
* children, more than 15mL/kg/hr
+ exchange transfusions in infants
+ patients with clinically significant cold agglutinins (patient produces autoantibodies which cause agglutination of red cells at cold temperatures)
+ rapid infusion of blood products through central lines
- blood should never be warmed in a bowl of hot water as this could lead to hemolysis (i.e. rupture) of the red cells which could be life-threatening when transfused
- a radiant heater should never be used to warm the blood being transfused because of the risk of hemolysis
- volume per unit of:
+ whole blood, 450ml
+ PRBC, 220-350ml
+ plasma, 180-270ml
+ platelets, 35ml
- material properties of blood
+ density 1.05g/ml (1050 kg/m^3)
+ specific heat 3490 J/kg*K
- medical tubing materials
+ polyvinyl chloride (PVC), most common (approx 30% of market)
+ polyethylene, second most common
+ thermoplastic elastomers (TPE)
+ nylon
+ silicone
- blood transfusion IV tubing catheter size
+ adults, 18 gauge (nominal inside diameter 0.838 +/- 0.038mm)
+ pediatric, 22 gauge minimum (nominal inside diameter 0.413 +/- 0.019mm)
- infusion/transfusion line diameter
+ outside diameter 4 to 7mm
- warming blood to temperatures greater than 42degC may cause hemolysis
- nominal capacity of a standard 12V car battery is approximately 45Ah
John Opsahl
