So this is what it looks like with the two way mirrored acrylic removed. A few notes in the construction. Make sure you have the same thickness acrylic, and cut the pieces so they are seated against the white box housing for the actual lights. That means the piece on top is going to be inset by the thickness of the resistors on the strip.
