Hackaday.io Hackaday.io
Sign up Log in
3D Printer Clog Detector V2
This is the second version of a device I designed to alert me in the unfortunate event the nozzle clogs. It communicates with the printer!
elite-wormElite Worm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
1 comments
2k followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
2.2k
1
2k
16
Team (1)
  • elite-wormElite Worm
Join this project's team
completed project
hardware
clog sensor clog detector jam detector jam sensor filament detector filament sensor 3d printer arduino attiny85 pcb
Related lists
Featured Projects
Featured Projects on Hackaday.io
This project was created on 06/24/2020 and last updated 5 years ago.
Description
This is the version 2 of a small device that allows you to detect if the nozzle of your 3D printer clogs while it's running. The building process is way easier now since it is based on a PCB instead of using wires. In addition to that, this version has a cool new functionality: It can communicate with your printer. That way you can automatically pause or cancel the print if a clog occurs. Jamming does not happen very often but when you are printing large parts it can really save you a lot of time to be alerted as quick as possible. It is attached to the top of the extruder using double-side tape and it is connected to the 12 V DC rail of the hotend fan. I printed mine in ABS to prevent deformation of some parts due to heat since my Prusa is enclosed.
Details
Log In/Sign up to comment
Sign up with Github
OR
nife87 wrote 06/28/2020 at 22:00 • point
Hard to know without any documentation, but you should consider both 12V and 24V power input if you have not already (most newer printers run 24V).
As an homage to the local Makerspace that closed I am building a scalable using parts from one of their broken printers
Project Owner Contributor
Printed Scalable Printer
patrick-ryanPatrick Ryan
I've taken a IKEA storage box (Moppe) and turned it into a CoreXY 3D printer
From IKEA Moppe to 3D Printer
thewretchthe.wretch
Official Hackaday Prize Entry
From slow single hotend semi accurate 3D Printer to fast and accurate dual hotend 3D Printer.
MDFStrap 3D Printer made with MDF
terry-batesTerry Bates
Top Lazy Susan metal pivot wore through, and it was old enough that replacement parts were no longer available.
Lazy Susan Pivot Repair
william-millerWilliam Miller
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printer Clog Detector V2", please tell us the reason.
Send message
Remove Member
