The M5Camera is a camera unit based on ESP32 chip has an OV2640 and also includes a PSRAM. As you may already know, M5Stack is an open-source modular toolkit for IoT developments based on ESP32. There are four versions of this camera (see Fig. 1). I got the M5-Camera B and this is a tutorial to use the camera to generate timelapse videos. However, this module doesn't have a microSD slot. Therefore, the application will publish the photos on an MQTT Broker, so that an MQTT subscriber can read and save them on a disk.
