Front Panel Design for my Kosmo 5u module
A project log for Witches Brew CV Joystick Controller
Let's you control any Voltage Control Synthesizer parameter with a Variable Voltage Output from +5V to -5V on a Joystick or other Controller
neil-mundtNeil Mundt 09/28/2024 at 20:520 Comments
I really like the Front panel that I made and will probably go with a similar layout/Graphics very easy to visually see the control for each knob. The control pots are directly connected via the 5-pin DINs connectors. Still need to do a proper Re-Design the Kosmo format is very popular now.
