Builders interview questions
1. What are the most three challenging parts of the build process? (In order of most challenging to least challenging?)
1.1 Describe, in a bit more detail, for each of these three challenges what makes them so challenging?
1.2 Have you ever had any ideas about what could make them easier?
2. What are the most three time consuming parts of the build process? (In order of most time consuming to least time consuming?)
2.2 Describe for each of these three challenges what makes them challenging?
2.3 Have you ever had any ideas about what could make them faster?
3. What Skillsets do you practice?
4. What tools do you commonly use, both within and outside of this project?
5. What software do you commonly use, both within and outside of this project?
6. What is the most limiting factor of the build:
a. Human Strength
b. Human Stamina
c. Complexity (Physically)
d. Complexity (Intellectually)
e. Other
7. Are there any other changes to the build process you have thought about making?
8. What is the most useful innovation (technical/practical) you apply when building the domes?
