Rubik's Cube with No Moving Parts
A frictionless speed cube. 54 LEDs and 108 capacitive touch sensors.
This ongoing project aims to create a Rubik's cube with no moving parts; a statement that appears contrary to the very definition of a Rubik's cube. In order to achieve this I have designed a 3D printed frame for the 6 cube faces that each hold 9 small acrylic tiles to diffuse the light emitted from 9 RGB LEDs placed behind them. In order to solve the puzzle, instead of rotating the cube as is traditional, the user will swipe their finger across the face of the cube. Using a total of 108 brass capacitive touch sensors the software will distinguish between a "swipe" and the random touches of a user simply holding the cube. When a “swipe” is registered the LEDs will change colours to reflect the "rotation" of the cube.
If you are interested in this project please follow along as I finish development of this project; if you have any suggestions please leave a comment or shoot me a message.
Hardware overview
The cube is made of 6 identical* face pieces that are designed to interlock with each other; each face has 9 acrylic tiles for diffusing the LED light and 18 brass square rods that act as capacitive touch sensors. Behind each of these faces is a circuit board with 9 different RGB addressable LEDs. The circuit design is discussed further in the next section.
The acrylic tiles are 3.175mm thick with a side length of 15.5mm; they are supported in the 3D printed frame through a friction press and a small 0.5mm lip in the 3D printed frame to ensure they are not pushed in too deep. The edge acrylic pieces have their sides tapered at 45 degrees (see pictures), the current design utilizes friction to hold them in place but they could be glued in place too.
The brass square rods are 3.175 x 3.175 x 15.5mm and also held in place through friction. Small channels are cut in the 3D printed frame for connecting the brass rods to the PCB via wires.
Inside the cube, the six cube-face circuit boards are connected to a seventh control board and communicate via an I2C bus. Behind the circuit boards is a smaller cube-shaped void, in this void a lithium-ion battery is placed.
In the first image note the small channels that connect the PCB board behind the frame to the brass capacitive touch sensors at the front of the frame. In the second image you can see a the 3D printed model with 9 acrylic tiles and 1 of the 18 brass capacitive touch sensors.
*modification is made to one of the faces to allow for a battery charging port
Electrical overview
See block circuit diagram in the pictures for a broad overview of the circuit
Each of the 3D printed frames has a two-sided circuit board mounted on it. On one side will be 9 RGB addressable LEDs for displaying the colour of the Rubik's cube tiles. The 18 brass capacitive touch sensors will be connected to the circuit board via short wires that fit into the channels cut out of the 3D printed frame, these 18 signal lines will be split into two groups running to one of two MPR121 chips. The MPR121 is a 12 channel capacitive touch chip with four I2C addresses (datasheet link). Due to the limited number of I2C addresses and the need for 12 MPR121 chips (2 for each of the 6 cube faces) a central I2C switch is included for cycling through each of the 6 circuit boards. This central I2C switch is mounted on a seventh control board, that is positioned in the central void of the cube, next to the battery. In addition to controlling the I2C communication it will also have a microcontroller, voltage regulator, and charge control circuits.
Software overview
The microcontroller will be responsible for periodically collecting the binary state of the 108 capacitive touch sensors (touched/not touched). If a row/column of capacitive touch sensors on any of the faces are touch one after the other and within a certain time threshold a “swipe” will be registered and the LEDs will change colour to reflect a ‘rotation’ of the cube. Touches that are detected that are not part of a “swipe” will be ignored since in order to hold the cube the user will inevitably be making contact with some of the capacitive touch sensors.
Existing Problems
There are two noteworthy shortcomings in the current proof-of-concept design: cube size and battery life. The current design has a side length of 65.3mm whereas the standard Rubik's cube has a side length of 57mm. In hindsight, I could have made a design that adheres to this measurement but I have already cut all the acrylic pieces by hand (most of which are tapered at 45 degrees on one or two of their faces), and I would rather not go through this laborious task again. After all this is merely a fun, proof-of-concept project.
Secondly, the short battery life (currently) prevents this project from being little more than a novelty. I am using a 3.7V 1800mAh lithium-ion battery; this was...
  • Build Log 1: Fabricating PCBs
    Will Donaldson10/25/2020 at 01:41 0 comments
    This build log documents the PCB design of the 6 identical boards for each of the 6 cube faces. Recall from the 'Project Details' section (above) that there will be a 7th central PCB that has a microcontroller and is responsible for power regulation. Each of the 6 cube-face boards have the following features:
    • 9 WS2812B LEDs (datasheet)
    • 2 MPR121 chips (datasheet)
    • 18 through-holes for connecting brass capacitive touch sensors
    • 4 mounting holes (M2 mounting bolts)
    • Additional through-holes for inter-PCB cabling
    Below are images of the top and bottom PCB traces (red and blue lines, respectively). Note that some traces appear to be touching, this is not the case; I was merely sloppy and used a screenshot then poorly compressed the image. I will not be publishing any of the design files until the project is finalized.
    The topside has the 9 LEDs chained together and can then be connected to the neighbouring board, once connected there will be a continuous strip of 54 addressable LEDs instead of 6 segments of 9 LEDs. Matrix rotations will be used for calculations in the software.
    The bottom side has two 12-channel MPR121 chips with different I2C addresses of 0x5B and 0x5C. These chips were chosen as the I2C protocol allows for easily checking the state of individual capacitive touch sensors as opposed to a convoluted multiplexing network. This will make developing the software that monitors for "swipes" easier (and faster). I unfortunately could not source an alternative 18-channel capacitive touch chip with I2C. If you wish to replicate this project please be aware that this chip is a legacy device and not recommended for new designs, however since this is a hobby project and not something I plan to make commercially this was not a concern (available for purchase here-as of Oct. 2020). Furthermore, on a personal level, I wanted to practice reflow soldering with a QFN chip (quad-flat no-leads).
    Note that 6 of the 18 through-holes for connecting the brass capacitive touch sensors are on the edge of the board as castellated holes. While not my first preference this was the only way I could devise that connected the PCB to the corner capacitive touch sensors without interfering or block the light from the LEDs.
    The PCBs were manufactured by OSH Park (not-sponsored).
    Assembling the PCBs was done with reflow soldering using a hot air gun. I would recommend doing the bottom side first to get the QFN packages out of the way. Below is an image of the assembled board mounted on a test rig.
View project log
