Without going into a lot of details, I designed the TMD-1 console. I created the following DXF files.
Tape Panel Box
![](https://cdn.hackaday.io/images/3370891597437512539.png)
Finite State Machine Panel Box
![](https://cdn.hackaday.io/images/931651597437512525.png)
Console Frame
![](https://cdn.hackaday.io/images/6000751597440488879.png)
I laser cut them from 6 mm plywood. Once assembled I painted the whole console a light gray color.
![](https://cdn.hackaday.io/images/3605851597441239724.jpg)
![](https://cdn.hackaday.io/images/4118151597441239785.jpg)
You can see in the above photos where I added some Velcro to hold the panels in place.
While there is still a great deal of wiring and programming work to do, this is pretty much what the final project will look like.
![](https://cdn.hackaday.io/images/7464511597441379552.jpg)
In this photo you can also see the finished "programming" tiles and a rack I made to hold them. On to the wiring.
