Having decided that the Tape would be of a fixed size with endmarkers, it was time to consider the underlying implementation. Given the fixed length it seemed simplest to have the Tape be stationary with a movable Head.
Since the endmarkers are immutable, only the inner cells of the tape would ever change between 0 and 1. Such a binary implementation could be accomplished in number of ways including a simple on/off LED. I thought about 7-segment and LCD displays. I started thinking that something more analog would be a good fit for this project and Flip-Dots (Flip-Disks) came to mind. Then it struck me, not Flip-Dot but...
Introducing Flip-Bits
I'll just string eight of these together to form the "input" area of my tape. I'll call that a Flip-Byte ;-)
Making a Flip-Bit
First print the parts. The STL files have been posted to this project.
![](https://cdn.hackaday.io/images/6117501594608285673.jpg)
You will also require a standard SG90 Micro 9g Servo (from Amazon: SG90 Micro 9g Servo For RC Airplane Car Boat Genuine).
Glue the 1 and 0 pieces together. Use the pegs to help align the two pieces.
![](https://cdn.hackaday.io/images/7213141594608706547.jpg)
![](https://cdn.hackaday.io/images/8633641594608706714.jpg)
To prepare the servo cut down one of the included horns at the third hole from the center.
![](https://cdn.hackaday.io/images/7006041594608983062.jpg)
Make sure the servo is in it's 0 position. I hooked mine up to an Arduino and wrote a small program to do this. Attach the horn parallel to the long axis of the servo as shown below.
![](https://cdn.hackaday.io/images/193731594609164626.jpg)
Slide the 0/1 flipper piece loosely into the base.
![](https://cdn.hackaday.io/images/463461594609238256.jpg)
Insert the servo into the base then push the flipper onto the horn.
![](https://cdn.hackaday.io/images/3638921594609321742.jpg)
Finally snap the c shaped spacer onto the flipper shaft to hold everything in place.
![](https://cdn.hackaday.io/images/194591594609519752.jpg)
And voila, a Flip-Bit.
![](https://cdn.hackaday.io/images/4434541594609610510.jpg)
To test the Flip-Bit:
#include <Servo.h>
// Create servo object to control a servo.
Servo myservo;
void setup() {
// Attaches the servo on pin 9 to the servo object.
// Adjusts the min and max pulse widths, in microseconds,
// corresponding to the minimum (0-degree) and maximum
// (180-degree) angles on the servo.
myservo.attach(9, 500, 2450);
void loop() {
// Show the zero.
myservo.write(0);
delay(500);
// Show the one.
myservo.write(180);
delay(500);
I found that I had to tweak the min and max values for the servo attach() method to get the flipper to line up horizontally.
