One might think having an eight cell "input area" would limit the tasks TMG-1 could perform. In actual fact I could not find any interesting programs that could not be run in eight or less cells on an unbounded tape. What does interesting mean? Well the program would have to do something non-trivial (something more than writing a single symbol to the tape) and then stop. Stopping is important because there is nothing interesting about a program wondering down a tape to infinity (at least after the first millennia or so).
To be brutally honest, there is only one program that runs on on a 2-symbol (assume the b is not used)/ 3-state Turing machine that is truly interesting, the "busy beaver". The busy beaver "game" consists of designing a halting, binary-alphabet Turing machine which writes the most 1s on the tape, using only a given set of states, in this case 3-states. By definition a busy beaver program running on TMG-1 is prohibited from using the endmarker. symbol I won't spoil the ending but this programs runs fine in eight cells.
In actual fact implementing TMG-1 as an Linear Bounded Automata suddenly makes it a lot more interesting and fun. Being able to determine the beginning and end of the input area is key. With this little LBA we will be able to:
- Treat the input area as a binary number and find the one's compliment. (Making the input/tape alphabet 0 and 1 was not by accident in this case, although by convention this is often the case. ;-)
- Find the two's compliment of the "binary" number in the input area.
- Count in binary (ascending and descending).
- Sorting. Move all the 1's in the input area to the right or left.
- Shift the input area one cell to the right or left (multiply / divide by 2).
- Make a Cylon eye with head lamps ;-)
You get the idea. As an LBA the Turing Machine Demonstrator is a much more capable teaching tool even with only eight cell for the input area.
