"Lora and I, a Simple 3D Printed Automaton" is an updated version of the first automaton I designed, 3D printed and assembled about nine years ago inspired by various versions I'd seen at craft shows and on line. This version is sturdier, requires fewer parts and is hand operated so no motor or power source (other than you) is required!
3D printing and assembly of this model is quite easy and it makes a great first automaton. Along with all .stl files required to 3D print this model, I've also included the file "Lora and I.f3d", an Autodesk Fusion 360 CAD file containing all steps I used to create this model. This file may also be used to customize the model to your liking.
