Setting the earth battery up
A project log for circuit sculpture Fail-o-rama
Circuit sculpture using electroforming for organic-ish blinkenlights
jonJon 07/10/2020 at 05:590 Comments
I hammered in the copper pipe, but after getting the lag bolt in finger tight I had to bring in the big channel locks to tighten it in.
For earth battery aficionados, The cathode and anode are arranged east-west and at a distance of about 8 inches, so I expect that I am not impacted by telluric currents, but with my excellent failure rate I am wide open to being offered additional reading material. Also, I don't know my soil composition, so as an electrolyte it's properties are open to broad speculation. The soil is not particularly wet or dry ( I sure could use a series of earth-battery powered soil sensors)
