I was having intermittent CPU issues. These manifested as intermittent results uploading S-Records. Sometimes I'd even make an identical build which would work one time but not the next. Something was marginal in the design.
I hooked up a logic analyzer and added test points to the I/O connector to monitor some of the internal control lines of the CPU.
IO_PIN(48) <= w_cpuClock; IO_PIN(47) <= n_WR; IO_PIN(46) <= w_nLDS; IO_PIN(45) <= w_nUDS; IO_PIN(44) <= n_externalRam1CS; IO_PIN(43) <= w_wait_cnt(3); IO_PIN(42) <= w_n_RomCS; IO_PIN(41) <= w_n_RamCS; IO_PIN(40) <= w_busstate(0); IO_PIN(39) <= w_busstate(1); IO_PIN(38) <= cpuAddress(15); IO_PIN(37) <= '0' when ((cpuAddress(23 downto 3) = x"00000"&'0')) else -- X000000-X000007 (VECTORS) '1';
The 68K CPU has two bus state lines which indicate the operation being performed. They are documented as follows:
busstate : out std_logic_vector(1 downto 0); -- 00 -> fetch code -- 10 -> read data -- 11 -> write data -- 01 -> no memaccess
Disabling accesses for the situation where the busstate = 01 cleaned up the issues I was having. Also, making peripheral accesses only active when busstate(1) = 1 protects the port a bit. RAM and ROM can have either code or data so they need to access for the situation where busstate{1) = 1 or busstate(0) = 0.
Here's the timing of the CPU coming out of reset:
This fixed the CPU so that it runs reliably at 25 MHz including downloading S-Records and running code. It broke the External SRAM but that's OK since I wanted to work on the controller anyway.
