Added GPIO ports to FPGA design.
Features
- Input/Output ports
- 3 bit port
- (2) 8 bit ports
- Two locations from CPU
- Register/port selection - indirect
- Set bit direction
- Data port
- Connects to J2 connector
Indirect Register
-- 0 DAT0 bits [2:0] -- 1 DDR0 bits [2:0] -- 2 DAT2 bits [7:0] -- 3 DDR2 bits [7:0] -- 4 DAT3 bits [7:0] -- 5 DDR3 bits [7:0]
Data Direction Register Bits
-- 0 in the data direction register marks the bit as an output -- 1 in the data direction register marks it as an input
After reset, GPIOADR=0, all DDR*=0 (output) all DAT*=0 (output low).
Route to DB-25 on MultiComp in a Box design.
