Great improvements on Makerfabs Lora Soil Moisture Sensor V3!!!
- TLC555 removed, while the Atmega328P(D9/Timer1) generates the 2 MHz pulse (only during the measurement phase, switching off afterward), for capacitive moisture measurement.
- Unique ID by default, for easy/fast usage as getting it on hand.
- Ultra-low-power consumption design on hardware& firmware, 7.1uA in sleeping mode, minimum 2 years working time with battery 2x AAA.
- Improved J3166 water-proof paint to enhance the lifetime of usage. It has outstanding moisture-proof, salt fog proof and insulation properties.
For more detail, please check here.
