The mechanical portion of this has been a struggle every step of the way. Worked on trying to install the latch plate, but can't get a screw driver in, so using tacs for now.
Also noticed the assembly that's holding the solenoid to the board is loose. I will need to add some lock washers to get a bit more bite.
