This is more of an add-on type of feature. For live streaming, I use OBS with the websockets plugin and lorianboard as a scene controller. Lorianboard is pretty awesome including features that allow you to trigger multiple sounds, scenes, and sub-menu controls. At its most complicated, it can even create a simple state machine control over obs based on twitch chat, channel points, and other non twitch related triggers.
Since my gestures already trigger a chat message: !wave_mode !random_motion_mode !speed_mode !fist_pump_mode. It is rather easy to trigger a button in lorianboard. While editing a deck, choose a button and select Edit Twitch Triggers.
Coding the effect itself is a little more complicated.
In OBS, create a scene for you to change to. Add in whatever sources you'd like.
For me, I recreated a green screen effect using machine learning and the yolact algorithm. So I included the source window generated from python and yolact. I also rewrote part of yolact to display only the objects detected or the inverse. I also provided a glitchy vhs background. Back In Lorianboard I created a button with a "stack" or queue for effects. It looks like the following. An if statement with variable to the corresponding effect, a bash script executed by lorianboard, and scene changing commands based on timers.
The bash script runs my yolact python file with line arguments.
python eval.py --trained_model=weights/yolact_resnet50_54_800000.pth --score_threshold=0.15 --top_k=15 --video_multiframe=20 --greenscreen=True --video="rtmp://192.168.1.202/live/test"
Notice my video is actually an rtmp video stream. I have an nginx-rtmp video server running in a docker container, which my phone broadcasts to using Larix broadcaster.
But Anyways the EFFECTS! Let's check out what I have created so far.
Pretty good for AI.
Inspired by Squarepusher's Terminal Slam video and some others work to recreate it. I tried my own varient.
