So... before I wrote any of the now (including this one) three project logs... heck, before this project's page went up, even, I'd done a couple days' work on it already.
Here's what happened.
I cut the pill bottle, kinda all at once... in retrospect, that was probably kinda dumb, lol.
![](https://cdn.hackaday.io/images/9743921595290008190.jpg)
A little retrofit work on the system unit...
![](https://cdn.hackaday.io/images/4066011595290479566.jpg)
![](https://cdn.hackaday.io/images/1848141595290525374.jpg)
![](https://cdn.hackaday.io/images/4496341595290566623.jpg)
Cut the pill bottle's cap, for a ventventlike cutting the bottle, this could have gone better. Oh well. Added the grill anyways.
![](https://cdn.hackaday.io/images/6171921595290658780.jpg)
![](https://cdn.hackaday.io/images/9530461595290705594.jpg)
Tried a bottle + cap test fit... yeah, that's gonna need some help. Namely, cutting the bottle rim down. I did... it uhm sort of worked...
![](https://cdn.hackaday.io/images/2955331595290805445.jpg)
The finished assembly, right before it uhm broke...
![](https://cdn.hackaday.io/images/3426501595290875601.jpg)
![](https://cdn.hackaday.io/images/4469281595290885589.jpg)
![](https://cdn.hackaday.io/images/7931981595290890214.jpg)
![](https://cdn.hackaday.io/images/5899471595290896145.jpg)
![](https://cdn.hackaday.io/images/3595891595290895986.jpg)
...and then I broke the bottle, in a way I couldn't fix :(
Since then, I've acquired a replacement bottle, and made two design changes, one affecting Vyxen, down the line... stay tuned ;)
