Now that the input and output work, it's time to work on the command line. At a high level, a notional set of commands could be:
- mnt - mount the SD card, load/parse the boot record
- dir - fetch the directory from the SD card and display to the screen, starts in root folder
- cd - change directory
- ld - load a file from the SD card
