Not sure if there's something wrong with the other SD card, but I tried a couple of other cards and they worked fine. Here's the capture from the BASIC program.
BASIC Code:
100 REM OSISDOS PROTOTYPE READ SD CARD IN BASIC 110 SAVE:REM TURN ON LOGGING TO SERIAL PORT 120 REM SDCARD BASE ADDRESS = $F010 (61456 DEC) 130 DT=61456:REM SDDAT 140 ST=61457:REM SDSTATUS/SDCONTROL 150 A0=61458:REM SDLBA0 160 A1=61459:REM SDLBA1 170 A2=61460:REM SDLBA2 180 DIM MA(512):REM RESERVE ARRAY SPACE FOR SD CARD DATA 200 REM INPUT THE LBA VALUES AND WRITE TO SD CTRLR REGISTERS 210 INPUT "LBA0 ";L0 220 POKE A0,L0 230 INPUT "LBA1 ";L1 240 POKE A1,L1 250 INPUT "LBA2 ";L2 260 POKE A2,L2 300 REM CHECK SD CTRLR STATUS, S/B 128 310 SC=PEEK(ST) 320 PRINT "SD CTRLR STAT =";SC 330 IF SC<>128 GOTO 310 350 REM WRITE 0 TO CONTROL REG FOR READ BLOCK 360 POKE ST,0 400 REM WAIT FOR READ VALUE READY 410 REM READ SD CARD INTO ARRAY 420 FOR MO=0 TO 511 430 SV=PEEK(ST) 440 IF SV <> 224 GOTO 430 450 MA(MO)=PEEK(DT) 460 NEXT MO 500 REM DUMP ARRAY TO SCREEN 510 FOR I=0 TO 31 515 SA=(I*16) 520 FOR J=0 TO 15 530 DV=MA(SA+J) 540 GOSUB 600 560 NEXT J 570 GOSUB 800 580 NEXT I 590 END 600 REM PRINT DECIMAL NUMBER AS TWO HEX DIGITS 610 NB=(DV AND 240)/16 620 GOSUB 670 630 NB=DV AND 15 640 GOSUB 670 650 PRINT " "; 660 RETURN 670 IF NB>9 GOTO 710 680 VL=NB+48 690 PRINT CHR$(VL); 700 RETURN 710 VL=NB+55 720 PRINT CHR$(VL); 730 RETURN 800 PRINT " "; 810 FOR OF=SA TO (SA+15) 820 IF MA(OF)<32 THEN PRINT "."; 830 IF MA(OF)>126 THEN PRINT "."; 840 IF MA(OF)>31 AND MA(OF)<127 THEN PRINT CHR$(MA(OF)); 850 NEXT OF 860 PRINT 870 RETURN
