I had the wrong address for the SD controller registers in my code. Fixed it and it works now.
The C code reads a 512 byte block from sector 0 into SRAM starting at 0xE000 (Bank 0).
/* OSISDOS.c - Minimal Operating System for OSI C1P/SuperBoard ][ */
/* SDHC card based disk operating system */
/* 8KB Microsoft BASIC-In-ROM has I/O support routines */
/* CEGMON has various hooks to the I/O in BASIC */
/* Uses Banked SRAM from $E000-$EFFF to buffer SD card data. */
/* Intended to fit within a small ROM space below CEGMON */
/* Target ROM space goes from $F100-$F7FF (1.75kb) */
/* Compiled using CC65 toolchain */
Memory Map
$0000-$9FFF - SRAM (40KB)
$A000-$BFFF - Microsoft BASIC-in-ROM (8KB)
$D000-$D3FF - 1KB Display RAM
$DC00 - PS/2 Keyboard
$E000-$EFFF - Bank Selectable SRAM (not detectable as BASIC RAM)
$F000-$FFFF - CEGMON Monitor ROM 4K
$F000-$F001 - ACIA (UART) 61440-61441 dec
$F002 - J6 I/O Connector 61442 dec
$F003 - J8 I/O Connector 61443 dec
$F004 - LEDS 61444 dec
d0-d1 LEDs are on the FPGA card
$F005 - Bank Select Register 61445 dec
d0..d3 used for 128KB SRAMs
$F010-$F017 - SD card
0 SDDATA read/write data
1 SDSTATUS read
1 SDCONTROL write
2 SDLBA0 write-only
3 SDLBA1 write-only
4 SDLBA2 write-only (only bits 6:0 are valid)
//#include "osic1p.h"
#define READ_BUFFER_START 0xE000 /* Banked SRAM */
#define WRITE_BUFFER_START 0xE200
#define LED_BITS_01 0xF004
#define BANK_SELECT_REG_ADR 0xF005
#define START_BANKED_RAM 0xE000
#define SD_DATA 0xF010
#define SD_CTRL 0xF011
#define SD_STATUS 0xF011
#define SD_LBA0 0xF012
#define SD_LBA1 0xF013
#define SD_LBA2 0xF014
#define READ_COMMMAND 0x00
#define WRITE_COMMMAND 0x01
extern void main(void);
extern void setLBA0(unsigned char);
extern void setLBA1(unsigned char);
extern void setLBA2(unsigned char);
extern void readBlock(void);
/* main - Test the SD Card interface */
void main(void)
/* Set to first bank of the banked SRAM */
*(unsigned char*) BANK_SELECT_REG_ADR = 0x00;
setLBA0(0);
setLBA1(0);
setLBA2(0);
readBlock();
/* issueSDCardCommand - Send read or write command to SD Card */
void issueSDCardCommand(unsigned char rwCmd)
*(unsigned char *) SD_CTRL = rwCmd;
/* setLBA0 - Set the least significant logical block address bits */
void setLBA0(unsigned char lba0)
*(unsigned char *) SD_LBA0 = lba0;
/* setLBA1 - Set the middle 8 bits of the logical block addr bits */
void setLBA1(unsigned char lba1)
*(unsigned char *) SD_LBA1 = lba1;
/* setLBA2 - Set the upper 8 bits of the logical block addr bits */
void setLBA2(unsigned char lba2)
*(unsigned char *) SD_LBA2 = lba2;
/* waitSDCardReady - Wait for the SD Card to be ready */
void waitSDCardReady(void)
* (unsigned char *) LED_BITS_01 = 0x1;
while (*(unsigned char *) SD_STATUS != 0x80);
* (unsigned char *) LED_BITS_01 = 0x0;
/* waitSDCardRcvDataReady - Wait for the SD Card to have data ready */
void waitSDCardRcvDataReady(void)
while (*(unsigned char *) SD_STATUS != 0xE0);
/* waitSDCardTxDataEmpty - Wait for transmit ready from SD ctrlr */
void waitSDCardTxDataEmpty(void)
while (*(unsigned char *) SD_STATUS != 0xA0);
/* readByteFromSDCard - Read a byte from the SD Card */
unsigned char readByteFromSDCard(void)
char rdChar;
waitSDCardRcvDataReady();
rdChar = *(unsigned char *) SD_DATA;
return(rdChar);
/* writeByteToSDCard - Write a byte to the SD Card */
void writeByteToSDCard(unsigned char outChar)
waitSDCardTxDataEmpty();
*(unsigned char *) SD_DATA = outChar;
/* readBlock - -Read a block from the SD Card */
unsigned short loopCount;
unsigned char * inBuffer;
inBuffer = (unsigned char *) READ_BUFFER_START;
waitSDCardReady();
issueSDCardCommand(READ_COMMMAND);
for (loopCount = 0; loopCount < 512; loopCount++)
*inBuffer++ = readByteFromSDCard();
/* writeBlock - Write a block to the SD Card */
void writeBlock(void)
unsigned char * outBuffer;
outBuffer = (unsigned char *) WRITE_BUFFER_START;
waitSDCardReady();
issueSDCardCommand(WRITE_COMMMAND);
writeByteToSDCard(*outBuffer++);
The program starts at 0x0300.
Type TE000,E05F in CEGMON to dump the buffer to the screen. It worked.
Compiler commands are:
cl65 --start-addr 0x300 -Wl -D,__HIMEM__=$2000,-D,__STACKSIZE__=$0200 -t osic1p -vm -m OSISDOS.map -o OSISDOS.o OSISDOS.c "..\..\..\..\..\PC Tools\srecord\srec_cat.exe" OSISDOS.o -bin -of 0x300 -o OSISDOS.c1p -os -esa=0x300 "C:\Users\HPz420\Documents\GitHub\Doug Gilliland\Retro-Computers\6502\RetroAssembler\retroassembler.exe" -d -D=0x0300 OSISDOS.o OSISDOS.DIS
Now, on to figuring out the FAT32 DOS directory structure.
