Add spaces to the directory listing to pad out to the size. New code is:
4600 REM 4610 DF=0:REM START AT FIRST ENTRY 4620 IF MA(DF+2)<>0 THEN GOSUB 4400:REM PRINT CURRENT DIR ENTRY 4630 DF=DF+32:REM ADVANCE TO NEXT DIR ENTRY 4640 IF DF<512 GOTO 4620:REM BLOCKS ARE 512 BYTES 4660 RETURN 4800 REM POKE LBA, CHECK STAT, READ BLOCK TO MA() 4810 GOSUB 3800:REM POKE LBA VALS 4820 GOSUB 2200:REM CHECK CARD INIT STATUS 4830 GOSUB 2400:REM READ IN BLOCK 4840 RETURN
Result is better
*** DIRECTORY *** SYSTEM~1. 0 HOCKEY.BAS 8377 HORSER~1.BAS 3014 HURKLE.BAS 1390 KINEMA.BAS 813 KING.BAS 8950 LABYRI~1.BAS 4988
land-boards.com
