BigBitch3D - 2020
A very large 3D printer build out of 2020 and 2040 extrusion, a RepRap conversion for TronXY X5SA or can be 100% self sourced
avrAVR
https://github.com/adamjvr/BigBitch3D-2020A very large 3D printer build out of 2020 and 2040 extrusion, a RepRap conversion for TronXY X5SA or can be 100% self sourced no special parts required 100% RepRap
# BigBitch3D-2020
BOM:
FRAME:
Metal:
- 4x 530mm 2020 Aluminum Extrustion
- 4x 587mm 2020 Aluminum Exstrusion
- 4x 530mm 2040 Aluminum Extstusion
STLs:
- 2x 2040VerticalCorner.stl
- 2x 2040VerticalCornerMirrored.stl
- 2x 2040VerticalCornerFullBaseCut.stl
- 2x 2040VerticalCornerFullBaseCutMirrored.stl
Hardware:
- 24x Cast Corner Brackerts for 2020 Exstrusion
- 97x M4X10mm Hex Socket Head Machine Screws
- 97x M4 Washers 9mm
- 97x M4 T-Nuts
CoreXYMotorPlateOutboardMotorMirrored.stl
Standard Tesselated Geometry - 438.56 kB - 07/16/2020 at 23:54
Download
Standard Tesselated Geometry - 800.38 kB - 07/16/2020 at 23:54
Download
Standard Tesselated Geometry - 800.47 kB - 07/16/2020 at 23:54
Download
Standard Tesselated Geometry - 571.96 kB - 07/16/2020 at 23:54
Download
Standard Tesselated Geometry - 571.86 kB - 07/16/2020 at 23:54
Download
View all 8 files
  • Frame Built! Prototyping CoreXY Motion Parts
    AVR07/19/2020 at 08:47 0 comments
    So folks, been working hard on this Big Bitch ! got the frame built, took apart the original TronXY frame and rebuilt it using the frame corners I printed, the two varieties included in the parts list. As of right now I am printing the motor mount plates for the CoreXY motion system , they mount the motors and bolt onto the top of the frame.
    Frame Design in CAD:
    Motor Mounts:
    Motor mounts printing:
    That's all for now!! I'll post a picture of it more completely assembled tomorrow stay tuned!
View project log
jiyang wrote 07/18/2020 at 10:48 point
hi! Where can I buy the control board
jiyang wrote 07/17/2020 at 01:14 point
cad file?
AVR wrote 07/17/2020 at 01:19 point
https://github.com/adamjvr/BigBitch3D-2020 you can print the parts for the frame right now. The rest is being test printed and assembled, i release parts as I make them and test them. In the end there will be a full CAD assembly in FreeCAD right now just STLs and STEP files.
jiyang wrote 07/17/2020 at 01:26 point
Selfless contribution You are noble
