Sub-Circuits:
- Power Supply: it is a fully assembled rectifier, filter and voltage regulator circuit, designed to operate satisfactorily to drive all other Sub-Circuits. It can also be used to teach/learn the operation of a rectifier and voltage regulators by adding berg connectors to make it semi-assembled and easy to conduct rectifier expiriments.
- Section A:
NON-INVERTING AC OP-AMP AMPLIFIER, INVERTING AC OP-AMP AMPLIFIER, DIFFERENCE AMPLIFIER.
Section B: SCHMITT TRIGGER, DIFFERENTIATOR, INTEGRATOR.
Section C: SATURATING PRECISION RECTIFIER (HALF-WAVE), DEAD ZONE, PRECISION FULL WAVE RECTIFIER.
Section D: RC PHASE SHIFT OSCILLATOR, WEIN BRIDGE OSCILLATOR.
Section E: SQUARE / TRIANGULAR WAVE FORM GENERATOR.
vybhav-nag
Snow
Justin Scott
mihai.cuciuc
Adrian Freed
This was a great course to start off with. I can honestly say that I felt like this was the first time I had enough motivation to truly go through something new and I can pursue best essay writing service uk to finish my academic tasks easily. I feel like I got an insight in the programming field, but also gained useful skills such as the ability to work independently and efficiently.
