White toner pt.2
A project log for vector-06c mini
A 50% size replica of my favourite 8-bit computer
svofskisvofski • 07/18/2020 at 22:10•0 Comments
Now that I have such a beautiful stencil, the rest should be easy, just spray paint through it. I remember from some previous experiences that spray particles would try to reach behind the stencil and that would make the edges fuzzy.
For the first test, I used a couple of drops of silicone glue to hold the stencil as close to the key as possible. The result looked promising:
However I didn't like using the glue. I decided to stretch the foil across the keys using two test prints as supports. Here's just a nice picture of sun projecting through the stencil:
(We have sun)
I used some tape, perhaps some other things, but the foil would never stay put. In the end I decided to just use some weights (don't put too much weight on it).
I tried to make the coats as thin as possible using a spray can. After 5 or 6 coats with some 5-7 minutes between I decided that enough is enough and it's time for the grand reveal.
The stencil prints always have these annoying connecting bits which I also had to add, or the stencil would not hold itself together. I touched them up using acrylic white paint on a tip of a smallest brush that I could find.
I'm going to seal it with transparent lacquer when it's fully set. If I were to try it again, I'd account for the fuzziness and use a thinner font.
Yay.
