Button | Function |
RESET | Reset all values |
SELECT | Select limit type in pause mode / change displayed parameter in charging mode |
INCREASE | Increase limit value |
DECREASE | Decrease limit value |
START | Start/pause charging |
Limit Type | Function |
mAh | Stop charging when electric charge reaches the selected value |
mWh | Stop charging when provided energy reaches the selected value |
mA | Stop charging when current falls below the selected value (this usually correlates with the state of charge of the battery) |
min | Stop charging after the selected time in minutes |
