It's very trivial, but it's still not a pretty sight with the power feed cables exposed, so I edited the model a bit to make a removable storage box.
The cable will be wrapped around the inside.
A project log for Turning your Raspberry Pi into a camera
The idea is to make the Raspberry Pi High Quality Camera look like a Camera using a 3D printer.
STL and STEP files are also new.
