I took a bit of a break from this project but no it didn't do anything else other than go up and down a pole but you can do all that stuff probably, But one thing I would do first is lighten it up a bit by using carbon fibre instead of those aluminium extrusions. ohh and it did fall once.
Really cool! I was thinking about something like this to climb trees to put up ham antennas. Much rougher surface than a pole, of course, but the idea would be the same. Have you given any thought to how your robot could work around obstructions? I'm thinking like fixtures or enclosures attached to the pole.
No sorry so far just strait objects like poles, I think to climb trees you would require something like limbs, And I haven't acquired enough skill points for that.
My mistake, should have clarified - here in Idaho we have Ponderosa pines that are straight pretty much from the root flare to 40' or 50' up. Almost no branches, so my guess is something like you built but with larger, softer wheels would work with the rough bark.
Great build so far, very inspiring. You might see a tree-climber from me based on your design - lots of uses for such a thing around here.
No so far it uses traction and pressure from tensioned springs from one side, And yes you can leave it there, Because the drivetrains are 6 converted servos its not gonna just slide down (since they are not that easy to back drive) when you cut the power to them.
Wonder if you considered a bow design on the top part, so it always wants to hug the pole like the transitioning part of the pole where it's tapered.
