Hackaday.io Hackaday.io
Sign up Log in
Serial Plotter
My Serial Plotter (written on Python) what does what I like.
tauno-erikTauno Erik
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
0 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.4k
0
11
8
Team (1)
  • tauno-erikTauno Erik
Join this project's team
  • Tauno Serial Plotter
  • snapcraft.io
  • flathub.org
ongoing project
Software
serial plotter python serial plotter
This project was created on 07/23/2020 and last updated 5 years ago.
Description
This is my standalone serial plotter. I like to use Arduino, Esp866 etc. and then I started to learn python and decided to make something useful. Something that I will use and what is missing now for me. Although Arduino Ide contains serial plotter. It is a little bit different.Written in Python 3 and Qt5. It is basically my first GUI application ever.Incoming data should be a string. Ending with newline character. Number can be separated with almost any character.Like:label2la15be17el28/31/42/54 78ora2b1.5c1.7d2.8/3.1/4.2/5.4 7.8But not with - unless it is a negative number:5-10-22-33-40-55-62-75Script will extract all numbers and generate graph.Tested on Ubuntu 19.10 and Windows 10.Sourcecode and run instructions are on Github: https://github.com/taunoe/tauno-serial-plotter
Project Logs
Collapse
  • Snap
    Tauno Erik • 01/09/2021 at 18:17 • 0 comments
    My Serial Plotter app is now in snap store.
View project log
Log In/Sign up to comment
Sign up with Github
OR
The Better Serial Plotter is a new and improved drop-in replacement for the Arduino serial plotter with many new helpful features.
Project Owner Contributor
nathanNathan
Turn an old broken TI92 as a Serial terminal (ex. for RaspPI 0w)
XtsTI92SerialTerm
franck-galliatFranck GALLIAT
A cross-plattform serial monitor/plotter written entirely in rust.
Serial Monitor and Plotter
hacknushacknus
Arduinos are great at interfacing with hardware. TouchDesigner is great at making graphics and sound. This shows how to bring em together.
Arduino muliple data to TouchDesigner
jerry-isdaleJerry Isdale
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Serial Plotter", please tell us the reason.
Send message
Remove Member
