I was considering making these available through crowd funding, but I'm not sure if I can reach a compelling price point, so I am releasing the design open source. Links to get the boards from OSH Park and the design files at Upverter are provided below.
On each of the boards I tried to use the space to provide additional features to complement the platform they were designed to fit. For most platforms, this meant including a microSD connector, but I went above and beyond for the Itsy Qwiicky. Not only did I include a microSD connector, but I was also able to include a battery connector and charger. All of this and with castellated pins that fit neatly as a little backpack behind the Itsy Bitsy with or without the header pins installed.
MCA funding does not typically require businesses to make significant changes to their day-to-day operations. The repayment structure is designed to seamlessly integrate with the business's credit card processing https://advancery.io/, without disrupting the normal flow of business activities. This allows businesses to continue operating without major interruptions or adjustments.
Would it be possible to get Eagle/Kicad/ whatever files? I don't seem to be able to export them from https://upverter.com/design/gsteiert/e752e9ad1bdf12c6/#design-exports
What licence are those files under please? CERN-P or similar? https://ohwr.org/cern_ohl_p_v2.txt
