Just a few quick hints if you want to build one:
buy the Etekcity EL11 scale. I haven't tested it with other scales
- use a pair of pliers to unscrew the (glued in) luggage-hook (counter-clockwise :) )
- open the scale (2 screws in the back)
- unscrew the PCB (3 screws)
- unscrew the load cell (2 screws)
- unsolder the load cells 4 cables
- solder 4 wires as long as you need them (don't go too wild, maybe 50cm max or so) to the board. note colors and position!
- push wires through the opening in the case where the hook was
- put PCB back
- close case and tighten fasteners
- add heat shring tube to the wires
- solder your extension wires (in the correct oder of course!) to the load cell wires.
- shrink heat shrink
- cut M3 threads into the load cell case
- put load cell into the case (secure each corner with a dab of glue)
- put on lid, fasten with M3 screws
The hole in the lid is 8.2mm to account for shrinkage after printing. 8mm steel rods or tubes fit well.
I added the STL, STP and FreeCAD files in the files section. Happy hacking!
Misc
- the PCB has programming/debugging pads easily accessible, haven't bothered looking if the scale maybe puts out a serial stream like many calipers do
- the scale has a thermometer included
- you can add another hole in the bottom of the case to add the luggage-hook back. That way you can still use it for measuring hanging weights. (this will bu quite uncomfortable because of the small case though)
Cheers, Jan
Very cool. I made a similar project for my dog's water bottle to let me know when the water gets low. Only problem is when it loses power then you have to lift the bottle off, reset the weight to zero and put the bottle back on.
Any idea how to allow the device to retain the weight and survive a power cycle? I'm using an ESP8266 (via MQTT -> node-red) for this so I can see the weight on my iPhone.
Thanks!
