Problem with the output is that the tracks are very narrow. When soldering or working with the PCB, any metal debris or mis-soldering causes short-circuits. The etched away tracks are so small that you need magnifying glasses to troubleshoot. Very time consuming.
So, since the gcode created, runs over the same tracks twice. I could make each run shifted from the adjacent run. Now the etched tracks are larger.
![](https://cdn.hackaday.io/images/1098911606765881595.png)
At 30pixels per mm setting the track seperation is circa 0.5mm.
Will update on real etched PCB.
