I received the components over the next couple of weeks. I then started building the project. I started tinkering with each component separately trying to understand them and interface them with the Arduino. I had to calibrate the pH sensor to ensure that its reading was precise at this time. I then started working on the final version of the code amalgamating all components together in the project.
