9 minutes ago Arsenio Dev tweeted about using a FT232RL and openFPGALoader to program a Colorlight. On AliExpress you can find them for 0.64€/piece, which makes them even cheaper than the STM32 :D
A project log for Chubby Hat
This projects goal is to design a PCB that turns the Colorlight 5A-75B into an easy to use development platform for cheap.
