I transformed an old General Electric clock radio such that - rather than dial into an AM/FM radio station, you choose a day/stage/set and listen to the music that you would have heard if you were there.
I leveraged most of the original hardware, but I created a new display, face-plate and labels to A) highlight the new functionality and B) fit the festival vibe!
Step 1: Use the four way switch to choose between Thursday, Friday, Saturday, or Sunday.
Step 2: Use the old radio dial to move to a stage (yes, the stage names are confusing: This, That, The Other, Which, and What)
Step 3: Use the clock set buttons to scroll between set times.
Step 4: Hit the play button, jam out.
Details
This is what the clock looked like, straight out of the eBay boxFirst peek insideCAD'ing up a new faceplateFresh faceplate, cut with the Shaper OriginStencilled and painted (and broken, just a little)Visual test with the 16-segment displaysNew button labels. Layered black/silver vinyl, cut on my Cricut MakerFinal tuner label, Cricut silver vinylJust before closing up
Components
1×
General Electric Clock, model 7-4630a
1×
Adafruit Feather M4 Express
Microcontroller
5×
MCP23017
IO Expanders (4 for LED segments, 1 for inputs)
1×
DFPlayerMini
Music Player with SD card slot
4×
Kingbright PSC08-11SRWA 16 Segment LED displays
Nice, putting in that alphanumeric display. I have a radio clock whose flip clock died so I replaced that with a digital clock; that was the extent of my modification, not as radical as your mod.
You definitely deserve to go into the restomod list.
