Finally got some time to program the most basic keystroke effect:
The code for it is rather simple:
def update_lights(self): i = 0 y = 0 dt = time.monotonic() - self.key_time for x in range(10): self.leds[i] = self.light(x, y, dt) i += 1 y += 1 for x in range(9, -1, -1): self.leds[i] = self.light(x, y, dt) i += 1 y += 1 for x in range(10): self.leds[i] = self.light(x, y, dt) i += 1 y += 1 for x in range(9, -1, -1): self.leds[i] = self.light(x, y, dt) i += 1 self.leds.show() def light(self, x, y, dt): r2 = (x - self.key_x) ** 2 + (y - self.key_y) ** 2 c = 255 - min(255, r2 * 30 + (dt * 10) ** 2) return c, x * 25, min(255, y * 50)
The key_x, key_y and key_time are getting saved in the matrix scan routine when a key is detected to be pressed.
