A9G GPS & GPRS Module Tutorial | Ai-Thinker | AT
Tutorial on the A9G module from AI Thinker which is loaded with GPRS/GSM and GPS capabilities to connect your Arduino/ESP8266/Pi projects.
Public Chat
Hey, what's up, Guys! Akarsh here from CETech.
Today, we are going to go through A9G GPS, GSM, and GPRS module from AI Thinker. There are several other modules as well such as A9 and A6 from AI Thinker which have similar GSM and GPRS capabilities but the special thing about A9G is that with GSM and GPRS capabilities it is GPS enabled as well and is capable in doing GPS related functions which gives it an edge over other modules.
In this tutorial, we will try the functioning of the GPS capabilities of this module and after that, towards the end, we will also check the functioning of the module in GSM and GPRS mode.
So Let's jump straight into it.
A6 AT Commands.pdf
Adobe Portable Document Format - 3.74 MB - 08/03/2020 at 09:23
Preview
a9g AT commands chinese user guide.pdf
Adobe Portable Document Format - 615.10 kB - 08/03/2020 at 09:22
Preview
AiThinker_Serial_Tool_V1.2.3.zip
Zip Archive - 95.05 kB - 08/03/2020 at 09:22
Download
GSM_commands.txt
plain - 1.80 kB - 08/03/2020 at 09:22
Download
GPS_GPRS_commands.txt
plain - 2.30 kB - 08/03/2020 at 09:22
Download
  • 1
    INTRODUCTION
  • 2
    Get PCBs for Your Projects Manufactured
    You must check out PCBGOGO, the leading PCB manufacturer with 10+ years in PCB industry, for ordering PCBs online for cheap!
     You get 10 good quality PCBs manufactured and shipped to your doorstep for 5$ and some shipping. You will also get a discount on shipping on your first order.
     PCBGOGO highly specializes in quick-turn PCB fabrication and PCB assembly from prototype to mass production. Their three factories cover over 17,000 M2, which are fully compliant with the standard of ISO 9001:2015 Quality Management System. All the fabricated PCBs and assembled PCBs are high quality and certificated with UL, REACH and RoHS. Till now, PCBGOGO has the ability to finish 3000+ PCB fabrication and assembly orders per day and the accumulated customers have reached up to 100,000+.
     Do check them out if you need to get PCBs manufactured or assembled. They welcome your sample order with PCB fabrication order quantity from 5PCS and PCB assembly order quantity from 1PC.
  • 3
    About A9G Module
    The A9G is a complete quad-band GSM / GPRS module that combines GPRS and GPS / BDS technologies and integrates it in a compact SMD package, saving customers time and money in developing GNSS applications. The A9G by default comes with a bootloader or firmware and hence it can be controlled using AT commands through Arduino, ESP8266, and Raspberry Pi as well. It can be used to connect modules such as Arduino and Raspberry Pi to the internet and can be used in a wide range of IoT applications and is ideal for IoT applications for home automation, industrial wireless control, wearable electronics, wireless location sensing devices, wireless location system signals, and other IoT applications.
    A9G SMD package uses the standard SMT equipment to achieve the rapid production of products, especially for automation, large-scale, low-cost modern production methods for the convenience of a variety of Internet of Things hardware terminal applications.
    For detailed reading about the functioning and the features of the module, you can refer to this link.
View all 8 instructions
