Reworked the board and did the following changes:
- 24V board
- 60A peak current - new MOSFETs
- Dedicated logic ground plane and power ground plane
- 4 layer pcb, much better heat dissipation
- 2 mohm current sensing resistors
- Smaller footprint temperature sensor
- 3.3V 3A buck regulator
- Price should be a bit lower
- Swapped DRV8323 for DRV8305, 5V min voltage
- Bulk capacitance located above each half H-bridge
David Gonzalez
