Use the Elecfreaks cutebot's ultrasound distance sensor and the Adafruit CLUE's proximity sensor to avoid objects. The cutebot's neopixels display the current action state.
Neopixel Color | Sensor | Action |
green | Ultrasound | going forward |
yellow | Ultrasound | avoiding an object between 20 to 50 centimeters away |
red | Ultrasound | avoiding an object 20 centimeters or less away |
blue | Proximity | avoiding an object seen by the proximity sensor |
You can find the code for this demo in the "Example" folder of the CircuitPython_CLUE_Cutebot repository.
Github Repository: https://github.com/jisforjt/CircuitPython_CLUE_Cutebot
