DemandPeripherals
An FPGA based robot/automation controller that comes with Verilog and a full Linux API
Public Chat
"Peripherals on Demand" is the idea of this FPGA based automation controller. It has over 25 peripherals implemented as Verilog modules, over 30 different interface cards, and a really nice Linux API. You can even control it using shell commands. All open-source but you can buy the circuit boards if you prefer.
Eliminate the uC from your next project!
The FPGA of choice is a "venerable" Spartan-3E. The Verilog makes heavy use of the Xilinx memory slices. OTOH, we can get 10 peripherals in a Spartan-3E-100.
Jacob David C Cunningham wrote 08/25/2020 at 19:27 point
Is it concurrent or is it like a schedule/interrupt?
