Projects using the SI4463
- Little Free Radio: various data rates (and likely also packet lengths)
- SPACE-HAUC Ground Station UHF and their linux driver
- Eleph
Commercial products
Kiwi-tec LAP-E01
- Works in 920.6 ~ 928MHz band, +13dBm, Japanese TELEC certification.
- Uses Speex codec, which as demonstrated below (doesn't perform as well as Codec2 on low bit rates:
- 125kHz bandwidth LoRa
- Internal antenna : -0.4dBi
Prior art
nRF24 based
- Long Range Arduino Based Walkie Talkie using nRF24L01 : many similar projects, all using the RF24Audio library.
RFM12 based
- Walkie Talkie Duino using RFM12B "open source" (only to the Kickstarter backers).
RFM22 based
Analog FM based
- DRA818V analog FM module (lots of harmonics, will need a license to operate)
- Auctus A1846S : HamShield (by Casey Halverson), also available in Mini version.
- HamShield on Tindie
- Kickstarter
- Hackaday.io
- Instructables
- Github
- InductiveTwig
Comparable projects
KISS modem interface
LoRa
HamShield LoRa (by Casey Halverson)
STM32
- https://www.digikey.com/en/maker/search-results?&k=getting%20started%20with%20stm32
- NucleoTNC
- https://github.com/x893/Codec2WalkieTalkie
- 1024kHz FIR filter for sampling audio downto 4kHz
- QMESH
- Uses libcorrect as FEC library
Christoph Tack
