After some rummaging about in the dark corners of the house, and yet more experimenting, I arrived at the following design:
So a cotterpin slides in some kind of plastic tube, and when the head of the cotter pin touches the washer, the ground and RST of the Wemos D1 Mini will be shorted, hence waking it up.
