These picture may be familiar for you from Twitter (https://twitter.com/tinyledmatrix/status/1282358115078414341). But will also put them here to get a more permanent space.
I designed this little Test jig to program #COPXIE - chainable, dual 5*7 tiny led matrix without needing to solder the Pin header. You can program the Attiny and test the SPI communication afterwards.
