Hooked up a higher power 5V supply to the jetson and tested the eDP LCD, good image and the jetson seems stable with the increased current.
hooked up 12V supply for back lights with 5V regulators to power the jetson
Using torch as testing back light, have ordered some white LED strip to add to the light box to switch between UV and white backlight.
