After receive the IR blaster, I opened it and I was very surprised that contain a ESP8266EX processor and a connector to simply program it.
So I proceded to map all and here are the list:
- a 8Mbit flash (1 Mbyte);
- 6 IR led connected to GPIO 5 (through 6 transistrors);
- 1 IR receiver (seems and TSOP32238 ) connected to GPIO14;
- 1 Red led connected to GPIO4 (through 1 transistror), usefull to show states;
- 1 Pushbutton connected to GPIO13
The only problem of this device is the flash memory. 1 Mbyte is enough for build all application but often isn't possible use OTA to upload your sketch via wifi.
So, I soldered a pin and connect to a FTDI interface to program the IR Blaster. To test I used a firebase database. See my sketch.
I also use the wifimanager library to configure the wifi access parameters on line .
The sketch is very simple. Create (if don't already exist) a tree structure on Firebase with the chipId ad root, and temperature, fan speed and power ad child.
Michele Scaramuzzi
flynnwt
Noah Pena
hello42world
KD8NSF
